CUTTING WOOD CLADDING ( AT ANGLES )
13 Oct 2006
Worcestershire
hi, need some advice, i want to clad a section of wall in my conservatory but i have no idea how to cut the angles at each end of wood..if you can imagine looking at a pyramid shape ( or triangle ) section of wall ( this is above my patio doors) i need install/cut the cladding to butt up against the conservatory roof beams which come down at an angle..is there a tool that i could buy ( called angle finder or suchlike) ? or is there another way of doing it ( i hope you understand the question.many thanks in advance .
Sliding Bevel should do it, draw a pencil line level with a spirit level then adjust the sliding bevel in the corner for the angle
The sliding bevel is in my top five of all time favourite tools.
sliding bevel it will be then !...thanks guys for the info...will test it a few times first on bits of spare wood...again thanks for the info :D
