I'm about to fit a shower which is to be pumped via a Salamander NP50 and a thermostatic mixer. The pump instructions recommend a 50 gallon CW tank. The existing tank is 50x50x50cm and I reckon this must hold about 25 gallons. Thing is, it looks like it's made of asbestos.
Like that stuff used for shed roofs when was a kid. Explodes when thrown on a fire.
Ahem.
So I'm told.
This tank only feeds the indirect HW cylinder (the WC and bathroom cold taps are mains fed) and I see problems if I tee off the pipe to the cylinder for the cold side of the pump.
So, I can't use the existing tank and I cant replace it with a 50 gallon due to the loft hatch being too small. I guess I will have to fit a 25 gallon tank at the same height just to feed the shower.
Will this two-tank setup work or do I need to fit a 50 gallon tank?
Cheers,
Paul.
Ahem.
So I'm told.
Cheers,
Paul.
