I'm connecting a vented indirect hot water cylinder to my central heating system, which is in an airing cupboard on the top (first) floor some way away from the boiler and pump. The pump is also on the top floor just aboce the boiler.
Unfortunately, there is no way to route the cylinder coil pipes under the floorboards - too many water and central heating pipes in the way.
It would be simple to route the pipes up into the loft and down again to the cylinder, but this would make them higher than the f & e tank.
Could I get around this just by increasing the height of the f & e tank? If so, by how much - it's a very small loft. Kind thanks in advance.
