Should be an easy one for you guys. (Im dense lol)
Can you get a Cylinder stat with a High and Low limit together or would I have to buy 2 seperate stats.
Its for a solid fuel heating set up. I want the pump for the rads to kick in when the 28mm return reaches 65 but then I want the pump to stop when it reaches 40.
Or would it just be better with one stat set at 60 and let it cycle all the time?
Hope that makes sense!
