I have recently noticed, normally about late afternoon, that our hot water cylinder is venting hot water and i dont know why, turning on a hot tap for 10 seconds stops it for about a day. The water flow is about a litre every 10 minutes.
The system is a solid fuel boiler, not lit at the moment, an immersion running for 2 hours a night set at about 63 degrees, the top of the cylinder has a vertical pipe with a tee, one going up to the loft and discharges into the tank which feeds the central heating system it is this pipe which has the running water.
Searching appears to give me 2 reasons for this water too hot, and coil leaking for central heating into the hot water system. Are the any other reasons? Before i change the cylinder, have i missed anything. The pipework and cylinder are about 20 years old, the cylinder is covered in cream coloured foam
