d v d / surrond sound
21 Jan 2004
when i buy a surround sound system ,does this mean that as well as getting dvd through the 6 speakers will the tv/ video also come through the system
Mine does ! You can either have the TV speaker or surround system speaker but not both. A lot depends on your TV plug in accessories unless your TV is very old. The details requirement will be on the box instruction.
thanks MASONA , should be ok as my tv has scart ,etc
thanks for yor help
steve :D
The best way to connect your TV is via a Scart to Audio lead, this way if you still use Video/Sky just set your Amp to the setting where you've connected the TV to and you should get whatever your watching comming out of your Surround/Pro-logic system.
