DAB Aerial (Dual Wall Socket) Clarification please
16 Oct 2005
Suffolk
I've got a regular TV aerial outside my house, but no DAB antenna, so I've just bought one. Inside the loft hatch I've found (I've just bought the house so its setup is new to me!) an 8-way booster/splitter that shows separate inputs for VHF and UHF, but 8 outputs to sockets, not specifying VHF or UHF.
Am I right in thinking VHF is radio and UHF is TV? And the TV and radio signals are combined as they travel through the same cables inside the walls of the house, then a dual socket will split the signal back out again??
Will the DAB aerial I bought still function the same through the splitter as the UHF aerial it was intended for? Also the wall sockets - I found these cheap:
http://cgi.ebay.co.uk/ws/eBayISAPI....akeTrack=true&ssPageName=VIP:watchlink:top:en
I assume they take one cable and split out the tv and aerial signals?
Let me know if I'm barking up the wrong tree!
The TV aerial is external, but inside the loft I can see they've kindly left a mounting pole for an aerial, I hope the DAB antenna I bought gets a good enough signal inside the loft!
Yes VHF radio and UHF is terrestrial TV but DAB is half way between the two there is no reason with the double frequency from Analogue Radio to DAB and DAB to TV why an aerial with traps could not be used in the same way as used by radio amateurs but I have not seen any for sale.
The method seems to be to use combiners and splitters so four aerials feed the box in the loft and then one cable brings it to each room where it is split again. Often with a second coax for the second sky box feed.
However many do not include DAB so neither the VHF or UHF will have the right filters.
Thanks for the reply - I ended up winning the ebay auction for the set of 4 dual sockets for 99p yesterday, so I guess I'll just try it out when they arrive! Hopefully it will do what I'm thinking!
Thanks Sam, that does look the same. I would assume the splitter in the loft must use the Diplex system two if it was two types of input but only one type of output. I'll wait for them to arrive and see!
