Your expert advice would be much appreciated.
I have an external, chimney mounted 4 element FM aerial. The chimney is about to be demolished, so I will be replacing with a wall mounted pole.
I would like to update to DAB, and still receive FM, but I need to stick to just the one down lead. (it would be almost impossible to run another)
I understand that a half wave FM aerial may do the trick. If so can I just split at the tuner, or is a diplexer required. If I need one - which one ?
