Dado Trunking Systems
BQW
15 Apr 2008
Isle of Wight
Are the socket back boxes from the different makes of Dado Rail Trunking, compatible and interchangeable ?
NNNNNNOOOOOO
Pulls hair out and jumps up and down.
Sometimes I've found it difficult to identify them too.
Post a pic here of what you have, chances are someone will help.
Most popular brands have the name embossed somewhere, MT, MK, Rehau, Mita but there are others about
As above, they are all different - and it is a right PITA. Sometimes the boxes will be marked, but some aren't - and then you are reliant on your wholesaler having someone with good experience and hope he can identify it.
It's a load of hassle, because (assuming you can identify the make & model) if it isn't something your local wholesaler stocks, then it'll be a special order item and delay the job by at least several days.
For many, this isn't part of the quote so they bodge it. There are a number of bodges possible, and every one I've seen is a bodge - looking like a bodge to a variable degree.
