Daewoo side-by-side Fridge Freezer FRS2021IAL
The fridge is not cooling, at 15C last I checked.
Freezer is keeping food frozen, but not as cold as it should be.
The air is not circulating properly, if at all, thorough both the fridge and freezer.
I removed lower back panel and found the coils and fan to be clogged with dust, so vacuumed them clear. The fan runs OK. Compressor is humming away quietly same as usual so I presume it is working.
No sign of frost anywhere, outer walls are not showing any signs of heat.
The digital front display is just displaying as normal, but does not appear to detect the high temperature in the fridge.
I haven't tackled a fridge before, so I'd appreciate any suggestions.
Many Thanks
Many Thanks
