Daewoo Matiz Heater Outlet Hose replacement.
7 Feb 2005
I have to replace the heater outlet hose on my 1999 Daewoo Matiz.( The hose running from the heater to the water inlet cap).
The Daewoo manual says a special tool is needed to release the hose clip at the heater end. Looking at it from above and below the car I don't see any other way of doing it. From underneath the car you can't see the clip because it is recessed behind the bulkhead.
There seems to be no way of accessing this clip with the normal range of tools.Molegrips about 18ins long with a 90 degree angular nose might do the trick!!!!!!!
Has anyone else managed this job?
Jeff
