Daewoo nofrost multiflow fridge/freezer problem??
11 Apr 2005
Merseyside
Hi
I have a 3yr old Daewoo Fridge/freezer, which has been working fine until recently. The model has a feature called multiflow, so when you opened the fridge door or freezer door, you could see the cool air pouring in through the vents, suppose to keep food fresher for longer. Foods are still being frozen and the fridge is still working, however the airflow is definitely not working as it use to, the fridge Light also went as well. I have since replaced the bulb, but the fridge is still not working as expected, any ideas on what has gone wrong with this appliance?
thanks for any advice
Vent tubes between freezer and fridge patly blocked with ice, first check the fridge door is closing correctly, turning the fridge light off, if you cant see the light switch when door is closed pull seal back when door is shut to see if light is on.
Colin
