Dallmer gully drain into 110mm pipe
22 Jan 2010
Sussex
Hello guys,
I have a Dallmer vertical drain to fit a showerlay board. The drain has to fit into a 110mm waste pipe coming vertically out the floor.
The vertical 110mm goes into a 110mm p trap so I don't actually need the trap of the dallmer.
My question is, does anyone know where I can get an O ring that has a 90mm ID, and a 110mm od to seal the Dallmer into the 110mm pipe?
Thank you in advance.
James
[/img]
i thought about that, but it's not really a standard installation and I don't think I've explained it very well. I actually want to put the dallmer into the 110mm pipe, a bit of a custom installation :)
J
