I can only assume we're talking about different things.
I'm not sure.
I did state a Ring Final as what I was referring to. A Ring Final requires the wire to be able to take 20A, not 32A. Logically anything used to make a join in a wire with a requirement to carry 20A must also carry 20A. Both the wire and the joiner will be subject to the usual safety margins so will not actually catch fire with occasional overloads.
The requirement is that the cable of a ring final should be able to take
at least 20A. Commonly, it would be Method C 2.5mm²cable, considered to be able to 'take' 27A, but there's nothing in the regs to say that one could not use cable with an even higher CCC than that.
Hence, the only thing limiting what current may pass through the cable (and any JBs) of a ring final is the OPD. If that has an In of 32A, then one surely has to assume that the current might be at least as high as that (in reality, higher), doesn't one, even if that current would theoretically 'overload' the cable?
If (as is commonly the case) it
were cable with a CCC of 27A, would you still say that a JB rated at 20A would be acceptable?
At the same time I would probably use something rated at 32A (if forced to use a connection), and I was just mentioning in passing that it isn't really necessary. I wish I hadn't bothered!
It's probably good that you did bother, since it has caused you to introduce a concept which you obviously believe to be correct, but with which I'm not very comfortable - and hence which I feel warrants discussion. IF I were concerned about the ratings of JBs (which, as I've said, I am not) then I would not be comfortable using a 20A-rated one in a circuit protected by a 32A OPD.
This discussion only becomes possible because, uniquely, he regs allow the cable of a ring final to have a CCC less than the In of the device protecting it. In any other situation, a cable which is compliant with regs will have a CCC at least as great at the In of the OPD protecting it, in which case I don't think the possibility of anything in the current path could have a rated 'CCC' less than the In of the OPD would ever arise.
Kind Regards, John
