damaged cctv leads
24 Apr 2006
Yorkshire
hi,
I wound if anyone can help, i have scrolled through internet without any luck.
I managed to screw up the leads (dc power plug and coaxial) connected on a dome camera i recenltly bought. These are the actual leads which are connected on the camera. the chock which splits the cables was stuck in an undersized cable gland and when i pulled at it, the cables came out.
I was to experiment and see if i can repair the camera. there appears to be three cables, re, yellow and shield (earth). can i simpley buy a dc lead with dc plug and install that to red and earth. i assume the yell is for video signal so would need a female BNC connector, is this correct?
any help would be appriciated.
cheers
And how would the video signal go without a common neg?
Ring up most suppliers they will sell the leads that come on a mini choc and fit onto the camera pcb board.
Try these they have boxes and boxes of spares http://www.henrys.co.uk/cctv.htm
Alarm,
Thanks for the response. can you recommend suppliers that you mention.
I will contact the website you porvided and see if they are able to help
cheers
hi,
Just to update, I managed to open the camera and inside was a 3 pin connector where the cable was attached.
I looked around the internet and found sourcingmap who supply the cable for under £2, just placed th order and hope the cable will be here next week.
