While not a plumbing question really, I wanted some opinions on how to reach a satisfactory outcome with this situation.
Plumber installed a new tank which sits above the kitchen ceiling. I had to construct the new deck for it and the positioning he wanted meant that the cold water feed needed to be re-routed under some other pipe work. It could have stayed on top but the plastic joint would have been pressed had against the deck and I asked him to move it, which he did.
Fast forward 2 days and we now have a large brown stain on the ceiling.
I have checked for Leaks as best I can due to limited pipe access and they all appear dry. Stain is also drying so I can only assume this is from water that came from the cold feed when he moved it.
He did tell me some water came out, about a cup full he said although it looks like he didn't place any towel under it or it missed! He actually sounded relieved when I asked if this was possible because a lot of pipe work is no longer accessible due to the routing he has chosen to take under the deck.
I have not paid the final invoice yet, Only the cost of parts, but in my mind, he should stump up for the damage caused?
Am I being unreasonable here as the entire ceiling will now require re-painting.
