Hi - would appreciated any advice.
we recently purchased a house (mid 60s build) and I have uncovered some problems with the drains.
To describe the site: there is no inspection chambers on my property, we share an IC with our neighbours. The main connection to the IC runs from our downstairs WC in a straight line. The IC is about 4 meters away however, the IC is 1.8 meters lower than the wc - the pipe gradients is nearly at 45 degrees!
I've excavated down to the pipe and there is two T joints about 60cm apart providing a branch for RW gullies and a Vent pipe. The main problem I have is the previous owner has "fixed" a blockage by smashing a 4inch round holes in the top of each joint. He'd covered these with broken pipe and backfilled...
i've not finished excavating and exposing the pipes becuase of wet weather but from what I can see, things do not look very good - the clay pipes seem mostly covered in concrete plus the trench is already pretty deep... Replacing the damaged joints looks like a really involved job...
Would having this section of pipe lined be a possible solution?
Any advice would be great
Phil
Phil
