- Joined
- 24 Dec 2014
- Messages
- 5
- Reaction score
- 0
- Country
Hey all,
After noticing a damp patch by the skirting board on the landing floor, which is just the other side of the shower wall/bathroom, I realised that there were hairline cracks through the grout in the lower tiles towards the bath. Bummer.
I chased the grout out of the tiles at the weekend and the 2 lower tiles literally fell away from the wall behind, as the photo below shows. By no means was the wall behind soaked, but it was certainly damp, and still is 2 days later (albeit it is definitely getting drier).
The cracks were most severe on the horizontal run above these 2 tiles that fell away, and there were hairline cracks that ran up the verticals that have been chased out, and minor ones along the horizontal further up that has also been chased out as well. As a result, I can imagine that the wall behind the 2 large tiles in the centre of the photo may also be a bit damp, although these 2 tiles are certainly stuck fast, which makes me think that most of that section is still okay.
Here's a close up of the wall behind those 2 tiles.
It looks like it's a lath wall behind it, and the wood was certainly flakier than it ought to be when I dug into it a bit with a spade bit...
I've also since realised that on the other side of that wall (which is on the landing), there is a section that has swollen slightly and is now a bit soft to the touch. That's my thumbprint you can see... The soft it is probably 15cm either side of the thumbprint. Note towards the bottom of the wall (approx 10cm below thumbprint) is solid, as is everything 15cm up from the thumbprint.
What do you reckon I should do? Should I look to get all of the damp affected materials removed and replace with new? I'm not entirely sure how this would play out with safely removing the tiles and the section of landing wall... Or would you be tempted to let it all air out/dry out for a few weeks and just whip the two tiles at the bottom back on? I can kinda live with that small section of landing wall being soft to the touch, it's at shin height and it's usually covered by a plant pot. Hmmm...
Any learned advice would be greatly appreciated, and thank you ever so much in advance for any advice you all have!
