I've just installed a new bath. The hot feed to the tap is from an existing 3/4in copper tube to a 22mm flexi tap connector, with a 3/4in copper olive. The problem is, that while not dripping, the joint remains damp. I've tried wrapping PTFE tape over the olive but it hasn't helped.
Am I worrying too much? As I say the joint is only damp to touch, and no water drips off it. Or should I try again to get a completely dry connection?
