Hi all,
Apologies in advance for the long post.
I recently removed the lino in the kitchen and found a damp patch about 1 ft long by 6" wide in the concrete floor. The back of the lino was mouldy in that area too.
Thinking that I had a leak from one of the central heating pipes buried in the screed. I know the pipes run near to this area from work done before. I carefully dug part of the floor up where it was the dampest. I have exposed the pipes and these are not wet or look to have been leaking. I dug a bit further and found the DPM to be torn in that section.
Under the DPM is sand which is damp also.
The damp patch is not near an outside wall or near any drains. It is in the middle of the doorway to the kitchen. I have shut the internal stop cock off for the water supply fearing that the supply pipe may be leaking and monitored the meter. The meter did not move over a full day.
Therefore I believe that becasue I am at the bottom of a gentle hill that this is rising damp.
Is there a way of repairing the DPM without digging the whole floor up?
Many thanks in advance for any advise.
