Probably a daft question but ...
I presently have the floor up in the extension so that I can modify the routing of cables and pipes etc.. And I have noticed that the concrete base can be noticeably damp on one side, under where an air brick is located. At first I assumed water was getting through the holes in the air brick, but on further investigation I am no longer convinced. The brick is well above the ground level, outside. And being a couple of foot max from the fence, I can't believe it blows in. In any case, to a *much* smaller extent, the base can get damp near the exterior door also.
Is this normal for houses ? Or something to be concerned about ? As far as I can tell the damp-proof course appears to be a few brick layers above the base level (although it doesn't stick out sufficiently to be obvious, I can just about see a black line in places) and damp isn't seen anywhere near the floor level. I just wasn't expecting the base to become wet each time it rained.
Cheers.
Cheers.
