Newbie here, so please be gentle!
I'm in the process of buying a 1920s mid-terraced house in South London. I had a full structural survey from a reputable firm who get consistently good reviews.
The surveyor highlighted damp meter readings that were '900-plus, off the scale' along the front bay window of the ground floor lounge, and then along one adjoining wall with the house next door - on which are two fireplaces about 3m apart. The surveyor used 'an Aquant electronic moisture meter'.
The whole of the downstairs has been made open plan, with an extension built in 2011 that spans the full length of the back of the house and extends to less than 3m (within permitted development).
The problem is, there is a laminate/engineered wood floor that covers the entire downstairs, so the surveyor was unable to confirm whether the original timber flooring in the old part of the house had beetle infestation, dry rot or other.
What he did note is that there are no visible air bricks out the back of the extension (though decking protrudes directly from the extension so it may be hiding them). The surveyor's concern was the extension was built without any adequate subfloor ventilation or air bricks, and therefore the original part of the house has air coming in the front (there are two air bricks at the front of the house) but not going out the back.
I'm now in a situation where the vendors don't feel there's an issue ("we've never had a problem") and can't produce detailed plans of the 2011 extension.
The council planning website appears to show the extension was approved retrospectively (though it's hard to 100% confirm this due to the lack of detail). The vendors did not do the extension - they bought off a developer in 2011 immediately after the work. The agent is unsurprisingly backing his clients.
My surveyor says the work to remedy the 'damp' would cost £8k-plus. The estate agent had someone go round yesterday and says 'there's no damp'.
I've spent the evening reading forums about damp, and the many myths that surround it. I feel it's foolish to ignore my surveyor (who I paid over £700 to!), but also know there's a lot of backside-covering with these surveys. Getting another damp specialist round is an option, but I've read that PCA ones will only try and flog you a DPC, and non-PCA ones will charge several hundreds of pounds and would still want to take up some of the laminate flooring.
We like the house but can't afford £8k to remedy something post-purchase and would need this factored into the price.
Any advice on what to do next would be gratefully received. It's causing many sleepless nights for me and my (heavily pregnant) wife!
