Hello,
We've got a fairly nasty damp problem in our bungalow with black mould growing on the wall.
The exterior walls are solid with no cavity (bricks are placed lengthways and then to tie to second skin at every other course - for example they look like this: ___ _ ___ if that makes sense!)
The DPC looks ok and is bitumen - bungalow was built in 1957. Surrounding one of the damp walls is a concrete path right up against the wall, about 150mm below the DPC, the other has bushes, and one has nothing near it/is clear. The internal floor has subsided (dropped by 10-20mm as an entire slab) and has come away from the skirting so you can see the DPC in the wall. I suspect a broken drain at the front but that has been diverted so no reason why the wall is still getting damp.
Any ideas what might be causing it? The walls seem to condense when cold out and warm inside.
We're doing some fairly significant renovations in the new year and hope to insulate the walls externally then render. The floor gets a little damp as well so was planning on putting a new damp membrane across the floor and up the walls to seal them and also injecting a new DPC around the house in case it was the DPC that had failed, then thin studding with foil insulation inside before plasterboarding. We the plan to lay rigid board insulation on the existing concrete floor and put underfloor heating in a screed on top.
Would this be ok or would this cause more problems than it would solve?
