Damp on gable end wall
26 Aug 2014
Good evening all,
I would like some advice please. I own an end of terrace property with an exposed gable end. The house was built in 1970 and the lower section is red bricks with the top section painted render.
Before I purchased the house in 2014, cavity wall insulation was installed in 2002 and I have a guarantee certificate from CIGA. Last winter, I started to notice wet patches/tide marks and salt deposits forming on the inside of my wall just inside the front door and into the hallway.
The damp patches are all from the floor upwards. I had a damp proofing company come out this week to have a look at this and they used a damp meter which showed high levels of damp not only on and around the patches on the wall, but several feet upwards as you walk up the stairs.
He used the damp meter on another external wall and this came back much better. The person from the company said he was 90% sure it was due to the cavity wall insulation and said it was likely that the insulation would be soaking wet. The only way to be sure of this would be to remove a brick or two and inspect it.
I'm covered by CIGA and the company that did the installation are still very much in business. I'm in the process of providing some photographic evidence and a small description of the issues I'm experiencing so that they can advise further. When speaking to them on the phone, they advised that they would likely need to get an approved contractor out to inspect the walls.
Now, my question is around invalidating my guarantee. The upper level of render is patchy and there is some loose paint. I was intending of removing the loose paint with a scraper and then painting the render whilst we are in the summer months. I won't be doing any structural work and nor will I be drilling holes or doing anything other than cosmetic changes.
The person I spoke to said that a guarantee could become invalid by 'tampering with the installation' but wasn't able to confirm whether me scraping off the loose paint and then painting the upper render would invalidate my guarantee or not. I won't be going near or disturbing the cavity wall insulation in any way and so I'd like your thoughts on whether I should be ok to go ahead or not.
Thank you.
dont do anything. nothing to the fabric of the house.
get a specialest RICS surveyor who does CWI remedial surveys to survey your property.tell them the story so far.
ignore whatever CIGA or the CWI company say.but let ther approved contractor come and do whatever after youve spoken with a RICS.
vampyr, good evening.
There are shall I call it "Several" threads on this forum regards CWI.
As bobasd, do nothing at all to the external surfaces of the wall.
Now for some night time reading and Information that may? assist??
http://www.publiclawtoday.co.uk/hou...-over-poorly-installed-cavity-wall-insulation
www.wallcavityclaims.co.uk/ciga/get-a-copy-of-your-ciga-certificate/
www.cewales.org.uk/.../Post_Installation_Performance_of_Cavity_Wall__External_
https://www.whatdotheyknow.com/request/informationreport_of_bre_on_cavi
Suggest you have a look through the above, then go back to the Guarantor and ask them to sort out the [note this word] DAMAGE to your property?
As for tampering with the installation, the installation is the CWI Itself and has nothing to do with you painting or re-papering the internal walls if you see where I am coming from.
As an aside how about you contact the local to you Citizens Advice Bureau, they may have a load of info regards other properties in your area that have been affected in the same way.
Now for the "Dark Side" of this CWI Fiasco, there are several Companies that [they claim] "Specialise" in seeking a resolution to your CWI problems these Companies also tend to work in "Insurance Claims" taking on Claims that have been rejected by an insurer or where the insured considers that the offer made by the insurer is insufficient as far as the claimant is concerned.
As for repair? WOW here we go, I have done this aspect a few times.
1/. Remove the defective CWI from the outside by several holed being hacked into the brick or block.
2. Cut holes into the lower area of the brickwork internally at low level on the ground floor and at high level in the upper rooms.
3/. Using a series of low volume dry air is gently blown into the ground floor internal holes to be vented at the upper floor holes.
4/. Remove all the wet contaminated plaster internally and re-plaster.
5/. Re-decorate internally and externally.
6/ Possible to introduce external fixed insulation plus render over this Insulation.
As above WOW this is no minor "FIX" this is a major total upheaval within the home???
Hope some of the above may be of use??
Ken
