Damp Patch to cover 2ft square???
8 Nov 2010
Hull
Hi all,
How can i cover a damp patch that is 2ft square, can i use foil backed plasterboard with dot and dab with a damp aditive.
This is next to a chimney breast.
Strange thing is there is no bricks under the damp patch for the damp to rise and there is also a joist underneath this that is bone dry??
We have had a chemical injection sometime back
The chimney breast is capped of and vents installed.
We just want some way to hide this as we cannot continue with plastering and decorating.
Any ideas for a quick fix as we have been living upstairs for 3 months now while works have been going on.
Simon
you need more than d&d addy for foilback you would also need mechanical fixings to hold it, but you wouldent want to d&d onto damp backgrounds anyway it wouldent last 2 seconds, it sounds like it could be condensation to me, "just a thought" .
It's defo condensation due to the capped stack.
sorry, when i say capped it is a vented cap so could it still be condensation??
thanks for your replys
simon
Yes. Most of those vented caps are worse than useless.
Sorry for sounding thick!! but how do you mean top and bottom
do i need 2 vents on the ground floor chimney breast??
Vent the stack downstairs, if it's an external wall you can do it from outside or in and vent it upstairs, The vented pots are no good.
You need some air flowing.
