Damp patch
9 Mar 2010
London
Hi guys have a small damp patch that keeps on coming through on a wall.
I am thinking of trying Toupret anti damp treatment is it worth a try? if yes any good tips, a small patch on the wall keeps blistering when re-painted.
Thanks Guys. [/u]
It sounds as if you either have a reaction between the paint and the background or more likely the reason for the damp patch has not been remedied.
If you have a local damp problem you should be able to isolate the cause and fix it, then you can go about the decoration side of things.
If you are able to post pictures of the damp spot inside and that same area outside it may be possible to offer a solution.
Hi I had the wall DPC treated about 3 years ago it seems that a small patch has come back in the last 6 months.
