Damp patches in/around pollyfilla in wall
6 Oct 2013
2 years ago when I moved in to my flat I pulled down some shelves from a wall in the spare bedroom, pollyfiila'd the holes then painted over. I used quick setting pollyfilla even though some of the holes were quite big, so possibly it didn't completely dry and set inside before I painted over. (stupid mistake)
All was fine until last winter. As it was never used I didn't heat the room and during the prolonged cold weather moisture entered the pollyfilla causing damp patches in the wall. I will try to post a photo.
To remove these should I cut out the pollyfilla and replaster, or is it sufficient to just cover over with a damp seal?
To fix it properly, you'd be best off ripping out anything that is wet or damp, and replastering. Perhaps some foam insulation might help also.
Using damp proof paint would be a temporary fix only.
Pics below of the affected wall:
I've chiseled out one of the damp patches:
Should I now treat this with PVA?
Will pollyfilla then be sufficient to fill again, or does it need to be plastered?
All you needed to do was whack a bit of oil based undercoat over the stains, and Emulsion the wall .
That may very well work. But PVA or some anti damp anti fungal prime would have a better chance.
Never PVA, and Emulsion over the top.
How big are the holes, I would guess polyfilla would do the job.
Plasterers use PVA under a thin skim. Why don't you tell them 'never'?
Sorry, I should have been more clear. :oops: Grip of course :)
