We had a new bathroom fitted about 5 years ago, at this time all the walls were skimmed. About 2 years ago the paint has started to bubble on one side of the cistern, presumably caused by damp coming from somewhere. None of the pipework was moved and I can't see anything wrong with the wall outside.
I decided to tackle this area today as I was using some damp seal paint, so scraped the paint off and it seems the plaster has bubbled too. There is also some peeling paint appearing at the other side now too. I have removed the dodgy plaster and paint but not sure of the best way forward?
If I just repair the plaster then paint it with the damp seal I can see it coming back again as the cause wont have been treated but I am unsure what the cause is I'm pretty sure that it's to do with condensation on the back of cistern, the wall behind the cistern is bare plaster. I guess it's soaking in there and spreading outwards through the plaster under the paint and causing the bubbling, or is this a wild theory?
If I repair the plaster then get the cistern removed and paint over the whole area with damp seal might this cure it?
View media item 64242
