I have damp in an external ground floor wall of a 1906 terraced house. The damp was evident due to rotten skirting board and paint flaking from the wall. I've removed the affected skirting and plaster to find that there are 3 or 4 places where the mortar in the header section of the brickwork at the base of the wall is missing altogether and I can feel a draft coming in through these gaps.
There is a chemical DPC so I'm assuming the gaps in the mortar has lead to water ingress, how should I go about filling these gaps? Is mortar alone sufficient or will this simply act like a wick to any moisture?
