hello knowledgeable ppl
someone has built an extension to our house, and the problem is the dpc is @ 9" above slab (1 block up from the concrete slab) the slab is the internal floor level
The blockwok has been rendered to the slab outside and to within 2" of slab level inside hence the dpc is bridged inside and out i have knocked off the render o/s to about 1" above dpc and the plaster inside to the same as to dry the wall this is now very unsightly what can i do (short of knocking it down & rebuilding it)
I obviously need to replaster inside to just behind the skirting but this will breach the dpc by 3"
I was planning a plinth almost up to dpc o/s and leaving a gap then continuing the render with a bell cast drip above the dpc?
Any advice??
Any advice??
