I am currently looking at buying a basement flat (Victorian building) and have had a damp survey carried out.
The survey suggests that horizontal/vertical DPC and tanking is required thoughout the majority of the property. I basically want to check if they have over quoted me!
I have been around the property myself with a damp meter, this particular meter goes up to 2.0% before it says the levels is too high with the symbol "ol".
The vast majority of the walls are in the 0.6-0.8 range however (from top to bottom):-
1) 1 wall is showing over 2.0% and thus "ol" this is all the way up from 30-40cm above the visible floor level (but only in the left hand corner) - this is clearly damp. How do I tell whether this requires DPC/Tanking or both?
2) Another wall oddly has a 2cm circle spot in the middle of the wall, this is clearly tanking.
3) Another wall has damp up to around 15cm from the inside floor level to where there damp is registered as OL, above this point the meter shows around 0.8-1. Is this likely to be a third party DPC that has been installed 15cm above inner ground level?
Basically I want to make sure that the quote is fair, as it could potentially stop me proceeding with the property.
Thanks all
Thanks all
