I have a 1880 Terraced House and around the fireplace in the back room (it's closed off) I've noticed a very slight dark line appearing about 30-50cms above the floor. I think this could be the start of rising damp so I've removed the skirting board and the plaster is in good condition (i.e. not blown) no salt deposits on it but is ever so slightly damp. The wall is fully internal (i.e. it's got next door attached to it) but I don't know whether I've got Rising Damp or it could just be water somehow getting down the chimney, or whether it's just as we've had so much rain the ground under the house (the house is built on almost no foundations!) is just saturated.
Should I just buy the Dryzone DPC Cream anyway and inject it in? I don't want to remove the plaster so can I just drill through the plaster and into the wall and inject it? Height wise can it be done just below the top of the skirting board so in effect I can just do it, stick the skirting board back over the top and leave it? Is it worth a go and if it doesn't work then I call in the professionals? Or once you've done it once does it cause loads of problems if you then need to do it again?
Sorry so many questions - would be great to know....
