could anyone tell me where the damp proof course is likely to be on a house with a suspended floor. There are vents around the bottom of the house, will the damp proof be below these and if so, by how much.
Thank you
how can I tell for sure if its above or below, my last house had quite a noticeable line where the damp course was but that was a new type house this one is 1900, what did they use for a damp course?
maybe slate or in a house that age there may not be one.
Look at your neighbours houses, any of them have lots of small holes around the air brick level (probably filled with brown plastic plugs) which may suggest an injected damp proof.
