Im hoping for some advice on what should be happening with the damp proof membrane mesh being installed in my very damp kitchen (mesh on all walls).
1. Should washer seals be used on all plastic plugs below window cill height
2. lots of holes have been drilled into the mesh that havent been used. Some sort of joining tape has been used to cover some, but am i right in thinking every single tiny hole needs to be covered
3. should all joins be taped
4. how are plug socket holes etc handled
5. how are holes where pipes go from inside to out handled
6. how are window and cills managed
7. There are some large creases around the chimney breast - is that ok?
8. How does ventilation into chimney get managed?
9. the membrane is being dot and dabbed, boarded and plastered. How would i then fix my kitchen units to the walls? (No battens have been used).
They have started plasterboarding the walls, so I really need to address this with them in the morning, before they have boarded over everything..
10. I was led to believe the guarantee for the work would be circa 20 years (as the building owner is around 55 years old, not likely to be tested out!), but what should i expect to receive (in writing) for a guarantee .. Im assuming its the builder guarantee and not the manufacturer guarantee ...
11. In addition, after receiving what now seems to be incorrect advice, I will be digging out the concrete floor and laying a DMP and insulation, before re-concreting. So effectively the room should be tanked. Anything I should be aware of, that springs to mind?
Any constructive advice or guidance you can give me would be hugely appreciated.
Many thanks in advance!
