Apologies if this should be in the painting decorating section!
I was thinking of painting around the base of my property (3-4 brick courses up) with some damp proofing paint to mitigate against water penetrating through the outer leaf.
I will be re pointing etc before hand and have done other works such as clearing cavities and adding air bricks.
The question is: What is the best thing to use? I have seen the clear stuff you can put on but then there is more thicker paint, of differing colours.
Finally - is it generally a recommend thing to do - any drawbacks? Is it worth doing in the combat against damp!?
