Hello,
I am planning to build my own shed - probably starting next Spring. The shed is intended to be more of an outside room, so will be insulated, and may well ultimately house an armchair and a beer fridge! I am happy enough with putting down an insulated, damp-proof concrete base.
I intend to build 3x2 framework walls. These will then be clad in plywood or similar, before finishing off with shiplap or similar
My main concern is to stop water soaking into the timber frame where the timber is secured to the concrete base. I am thinking that a solid plastic strip say 4 inches x 1 inch running under each timber wall would be a good solution to keeping the timber dry. I would then attach the framework to the concrete with the plastic strip sandwiched between the two.
Is this a good idea? Is there a better way to do this? Do such plastic strips exist, and if so where do I buy them?
Cheers
Neil
Cheers
Neil
