Hello - I’m hoping for some advice on my recently purchased Victorian end terrace.
The living room at the front of the house starts to smell fusty quite quickly unless the door to the hallway and a window are left open. The survey didn’t suggest any damp issues so I assume it is an air flow problem.
I discovered that the previous owners had blocked the chimney with a piece of plywood and sealed around it with expanding foam so there was no air flow.
The window board is a thin piece of ply, which I’ve removed - it reveals that the bay window has plasterboard around 30mm from the brickwork, with insulation pushed all the way to subfloor and blocking the air vents.
What would be a good way to tackle this? I’ve drilled through the board in the chimney and can feel the air, and removed the insulation from in front of one of the three air bricks and can feel the air coming up from there.
I’m happy to remove the plasterboard if needed and do it again with insulated board, leaving a cavity if that’s a good way to go; and to unblock the chimney - I have thought of boarding it again but including a hit and miss vent.
I’d appreciate any helpful suggestions.
Thank you!
Thank you!
