The loft of my 1964 bungalow (of conventional brick and tile construction) has 300 mm of glass fibre insulation (100 between joist and 200 on top). Not wishing to lose the use of the loft, I have installed 200mm plastic stilts. On top of the stilts are plywood pads of varying thickness (20-60mm) which compensate for the uneveness of the joists and keep the boards clear of the insulation. About 60% of the total loft is then covered in 18mm chipboard.
The problem is condensation on the underside of the boards in the vicinity of the wet room (which has an extractor fan). Condensation is not occuring in the insulation. I have taken up the affected boards and they are now dry. There is a small amount of condensation still taking place on the underside of the top of one of the plastic stilts.
Any suggestions please. I do not want to lose the use of my loft. It is the only dry storage space I have (not to mention the time and effort) and I am desparate to find a solution.
I would be most grateful for any advice
Julian
Julian
