About a year ago I noticed the hall wall was a bit damp-flank wall with outside rainwater drain opposite damp. I took up a floorboard and found it was wet on the ground near the wall and eventually found that the cement surround of the drain was cracked and leaking water downwards.
I fixed that by recementing it and the wet dried up and all was well.
Recently however, I've found about one meter up and about two meters length of the same wall is damp - worse than before. I've taken up floorboards and found it dry below.
A damp company says the damp proof course has failed and I need a chemical damp proof course.
Why would it have failed? and could there be another cause?
As far as I can see, water isn't leaking from the drain.
Advice much appreciated.
