- Joined
- 10 Jan 2004
- Messages
- 5
- Reaction score
- 0
- Country
I have 10 year old MYSON BF Wall Mounted combination gas boiler (sealed system). It has two seperate pumps, one for DHW and one for CH.
It has been leaking steadily, albeit a mere drip, from the top of the automatic air vent which is mounted on the air seperator.
Every couple of months the pressure would drop to less than half a bar and I would top the system up and bleed the radiators. This has kept the central heating and hot water working well.
Yesterday, the boiler just stopped working again. I topped it up as usual thinking it would just be a low pressure problem. However, for some reason when I fire it up now (HW on, CH off) and turn on a hot water tap, the water does not get hot at all. I cant even hear the boiler working and the pilot light justs stays low and doesn't fire up at all. When I turn off the HW and the CH on, the pilot comes on high and the pressure just starts to build up immediately. It goes from 1.5bar to 3bar within 15seconds and just cuts out.
Any ideas??? I'd really appreciate any pointers you can give me. I have no idea what is wrong. Could it be that the pumps have packed in?? Could it be an expansion vessel problem?
THANKS!!!
Laura
THANKS!!!
Laura
