DANAFOSS Radiator valve head removal
16 Dec 2004
Hello,
please could someone tell me how to remove the control knob, the plastic cap only that regulates the temperature. The system ws fitted 9 years ago and one radiator has not been used for a while and it was turned to the lowest position. I think the adjustment pin is stuck and will not let the rad heat up. There is a small pop up clip - done that but still can't lever off the control knob.
Thank you.
Hi
Done it - Lifted the small switch with a screwdriver - held the top and twisted clock wise and pulled off.
Re-fit - hold top and twist the bottom part and it clicks - line up groves, push down - it auto locks and push down the little clip.
