could be a number of reasons, no oil, blocked filters, solenoid coil faulty, pump coupling worn, pump faulty, motor faulty, photocell faulty or control box faulty.
Does it start up again once you press the reset button?
Is it noisy etc...
Your query as it stands is a little vague...
