I have a very old (40 years?) Worcester Danesmoor 15/20 boiler which has a Selectos burner. The burner was retrofitted with a Danfoss BFP 21L3 pump before my time with it. I have replaced most of the other things over the past few years.
What is happening now is that the boiler generally starts up OK and will run for periods of more than a day in some cases. More often than not it will fail after about 1 hour and lock out the controller.
I have watched it as it fails, and the process is that the flame fails but everything else appears OK until the photocell detects the failure and closes things down. Sometimes it picks up again before the lockout.
After the lockout period it always, so far, starts successfully.
It seems obvious that it is a fuel supply glitch, but I've tried bleeding everything in sight up to the filter on the pump. Is there some magic sequence which needs to be followed?
It could be the drive to the pump, which has been botched in the past, but I would expect a more definite failure in this case. These symptoms have been going on for two weeks or so.
Any thoughts would be welcome.
