Hi all
I posted a question about this before but am still curious to find out what the problem is. On my boiler burner I have an oil pump - Danfoss BFP 11 L3 - which heats up after about 10 minutes. It's about as hot as a very hot radiator, so you can touch it but not for long. It shouldn't be anywhere near this temperature. Here's some info:
-it's a one pipe system
-the horseshoe washer is present (present for one pipe, removed for two pipe. I presume its Danfoss's version of the bypass plug)
-I don't have the means to check pressure but it was bought new and the factory setting is 10 bar (145psi) and hasn't been touched
-nozzle is 0.40 USgal/h (for 100psi pump pressure)
My guess is that the pump pressure is too high for the nozzle but I've found charts that list the new USgal/h if the pump pressure is changed but no mention the pump heating up.
Any thoughts on this will be gratefully received.
