Danfoss radiator thermostatic valves
14 Nov 2007
I have just purchased 3 of the above from my local market to replace the ones on my radiators which are looking a bit tatty.
They are absolutely the same in appearance, but these have a small plastic box attached by a piece of uninsulated wire, and I need to know if the extra unit can be cut off and the thermostat head used as normal.
Regards vectraguy.
NONONONONO!
It sounds like you have got either something like a Tapstat, or a Remote Sensing valve.
Post a pic please
BTW Drayton Tapstats cost about £100 each, so you may be able to make a profit on fleabay
NONONONONO!
Post a pic please
Thanks for your reply JohnD, well these are brand new and cost £1 each.
I have removed the plastic top off the attached box and inside there is a metal core surrounded with a coil of the same uninsulated 14 swg wire that goes to the normal head part.
Sorry can't send a pic, but if you can imagine a normal Danfoss TRV these are exactly the same including the central cup that moves in or out as the dial is rotated to push the radiator valve closed or open.
Regards.
