Hi
I have the Danfoss Ret B RF Room thermostat and I have it set to position 3 which is 18C. Just recently I have noticed a few times that the room temperature has gone up to 19C so I have turned the Danfoss dial to check I have the dial set on 18C as it should be and as I turn the dial very slightly the flashing number that appears (as the temperature the thermostat is set to) is 30C. Obviously if the thermostat is around position 3 it is nowhere near 30C (which is position 5 normally). It appears that at times the room thermostat is getting confused and thinks it is set on 30C when it is in fact set on the 18C position, which means it is not telling the boiler to go off but is telling it to stay on to try to reach 30C! I have changed the batteries to see if that helped, but it has not. It seems that this may be a fault within the thermostat that has developed? There seems to be no problem with the way the thermostat is communicating with the RX1.
Can you confirm what you think the problem may be? Does it sound like a need to get a new RET B RF Room Thermostat? I would be very grateful for help! Many thanks
