Have you changed the battery inn the Transmitter?
Try bringing it closer to base unit
Failing that rebind
Failing that replace- these units do occasionally fail;
No, the green prog light only flashes when you bind the stat and reciever. The red ch1 light should come on where theres a demand, pressing the ch1 button overides it temporarily giving the demand.
Thanks guys. Problem system is at mum in laws. Got it running yesterday. Probably only in over ride. I put new batteries in the stat and tried syncing a few times. Saw green light on some attempts but not all. Will be a few days before I can get back to recheck.
