Dark imprints on new deck
10 Jul 2006
Hello,
I recently finished a brand new deck. The grass was looking a little worse for wear so I used some granulated weed and feed (kills the weeds and has grass seed too).
When it gets wet it has a faint chlorine smell (Best I can describe it)
Anyway, coincidently or not, a few days later some dull grey footprints or portions of footprints showed up on my deck.
Is it possible the chemicals caused the discoloration?
I tried the power washer with no luck. A very light sand sorts it out but I can't do that to them all because then there will be very light spots in the deck.
1.) Could the weed killer be the cause?
2.) Is there a way to get rid of the dull grey discoloration or will it work itself out as the pressure treated decking boards age?
I am planning to wait the suggested 6 months before treating the timber.
in my humble opinion
you will just make the problem worse[more visible] you are going to remove a chemical discolouration with more [assuming stronger] chemicals can only in my opinion look more blotchy
take 2 or 3 off cuts side by side in a long length replicate the foot prints in several areas leaving 2 untouched areas
try several "cleaners" overlapping both the decking and the foot print
im h o nothing will work untill you recoat or nature reduces the effects
