data backup
SL
17 Jun 2007
Suffolk
I tried to backup my PC to an external had drive, which took about 8 hours to copy files but then said you can't use backup as a backup disc could not be created as I do not have a floppy drive. Can I change any setting to it can create a backup CD. I have window XP pro.
Thnaks
Have you tried the Files and Settings Transfer Wizard?
I have not used MS backup but believe that you do need to have a floppy disk for system recovery. If you do a google search you may be able to find work arounds!
Have you considered buying an external USB floppy drive just for this purpose £10 -£15 e.g. HERE
Alternatively use a better backup solution e.g. Acronis True Image Here at £40
