- Joined
- 17 Apr 2009
- Messages
- 12
- Reaction score
- 0
- Country
Hullo
Landlord here. Yes, I know, probably you all hate me, since I'm responsible for the entire credit crunch.
However, I have a technical problem and am seeking help. Please.
I have an apartment with a Gledhill Pulsacoil 2000. Don't weep for me - just throw money.
It's had some work done on it recently - new immersion element, two new immersion stats, new pump, new heat exchanger, and I've since had a good lie down and recovered from the bill. Now the problem is that the water just isn't getting up to heat in the standard configuration.
As an experiment, the engineer has left it in such a way that the lower immersion element is available to be used 24 hours a day, instead of just during the off-peak period(s). This is great. Happy tenant == happy landlord, in theory. But this isn't as per the Gledhill design. The primary water is supposed to heat up, and thereby store heat energy, overnight, and release energy (via the heat exchanger) the rest of the time.
If the wiring is changed back again then the tenant can have a hot shower for a couple of minutes, then he says that the water goes tepid.
So what's the question? Well, I want to [somehow] record the pattern of electricity consumption in the two configurations, so that I can compare them. (Current in x time) == energy available, and I want to be able to see what's happening overnight without standing there for 7 hours with a clamp meter and a stopwatch.
There seem to be expensive (to hire or to buy) data logging devices that will do this, but I think my needs are less sophisticated then the price tag of these thingies imply.
Do any of you have an innovative way of solving my problem at low cost? And by "low", I mean that I'd be happy to spend around £25 on some device to do the job.
Thanks.
Thanks.
